Terrible speeds today
Started by wrtpeeps, Jan 24, 2008, 17:32:11
wrtpeeps
Yet again, terrible speeds coming my way. 0.3meg. Never had this problem before, why is it starting all of a sudden?!  >:(
Don't eat yellow snow.
No idea. Have you been able to run a BT speed test?
wrtpeeps
trying to run one now, going exceptionally slow.
Najarak
I'm getting very slow speeds, a disconnection at 16:15, speed test on speedtest.net at about 1200 kbps instead of my usual 6000 to 6500 kbps.
I've just done a BT speedtest which said :-
" IP profile for your line is - 7150 kbps
    Actual IP throughput achieved during the test was - 1090 kbps"
Am I right in thinking that this is likely to be a problem somewhere on BT ?
Quote from: wrtpeeps on Jan 24, 2008, 17:39:14
Are you using a version of IE? It seems to work better with that than Firefox.
Quote from: Najarak on Jan 24, 2008, 17:51:26
It sounds like it. I've just run a test and got as much as my profile would allow.
AndyG
#6
Quote from: wrtpeeps on Jan 24, 2008, 17:32:11
Yep, I'm seeing the same for the first time since joining IDNET.  Pings to the IDNET gateway look pretty bad from here: Min = 52 ms, Ave = 87 ms & Max = 292 ms compared with a pretty stable 30 ms normally.
Where about in the country are you? I'm in North East Wales.
Andy
wrtpeeps
Well I'm in Northern Ireland, so we can rule out BT can't we?
wrtpeeps
Also, cannot get bt speedtester to run  :-[
AndyG
Quote from: wrtpeeps on Jan 24, 2008, 17:58:54
Not necessarily, it depends on the ATM routing.
Andy
If it persists, all I can suggest is a call to support - it doesn't appear to be a local issue to your setups, eg internal phone wiring, so much more likely that BT has a network issue somewhere.
I've just got home and tested my connection and I'm getting full speed, as always.
If it helps, I'm on gw5 and based in Hertfordshire. :)
wrtpeeps
Just took me 45seconds to download 150kb.  :-\
AndyG
After several failed attempts, the BT tester shows:
IP profile for your line is - 5500 kbps
DSL connection rate: 448 kbps(UP-STREAM)  6272 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 378 kbps
I'll get onto support tomorrow if things don't improve.
Andy
Clearly it's not a profile issue, Andy, so support need to be kicking tyres from their end.
There's certainly something very strange going on that's affecting a few users' speed. Definitely get on to IDNet about this.
AndyG
I am on Rhyl exchange and getting exactly the same results as I always do for speeds and pings (interleaving on) with a 4000 profile
ou7shined
I'm in Aberdeen on a normally quite stable a 7392/448 Kbps profile with average pings of 27ms.
It took about 15 mins just to get this posted. :doh:
todays speedtest
todays pings
Rich.
Klaatu barada nikto!
Something's definitely broken somewhere, just managed to do a BT speedtest and got 124kbps download speed  :-[ I live in South West Leicestershire
Adam
While not nearly as bad as some of the above results, I'm see a speed test result of 2622Kbps on a ~7100 sync. I'd check my profile if the BT Speedtest tool actually worked.
Adam
RA-1972
speedtest
Just done mine only been connected with idnet for a hour so things are looking up .. :P
Adam
Out of interest, what gateway are the users having problems using?
Adam
ou7shined
Quote from: Adam on Jan 24, 2008, 20:02:09
How do I find that out?
Rich.
Adam
Quote from: ou7shined on Jan 24, 2008, 20:05:35
If you do a traceroute in command prompt it should be the second entry, the first being your own kit. For example;
  1     1 ms     1 ms     1 ms  * [*.*.*.*]
  2    47 ms    43 ms    44 ms  telehouse-gw2.idnet.net [212.69.63.55]
  3    44 ms    43 ms    43 ms  telehouse-gw3-gi0-1-400.idnet.net [212.69.63.243]
  4    44 ms    43 ms    44 ms  redbus-gw2-g0-1-331.idnet.net [212.69.63.5]
  5    44 ms    47 ms    45 ms  www.idnet.net [212.69.36.10]
telehouse-gw2 would be my gateway.
Alternatively, you could post your login realm (@uk.idnet.dsl4, or @idnet.gw5, or...). :)
Adam
My username is @gw5 but a tracert gives:
over a maximum of 30 hops:
  1     1 ms     1 ms     1 ms  home [192.168.1.254]
  2    44 ms    44 ms    44 ms  telehouse-gw2-msdp.idnet.net [212.69.63.51]
  3    44 ms    44 ms    44 ms  telehouse-gw3-gi0-1-400.idnet.net [212.69.63.243
  4    44 ms    44 ms    46 ms  redbus-gw2-g0-1-331.idnet.net [212.69.63.5]
  5    46 ms    56 ms    50 ms  www.idnet.net [212.69.36.10]
Trace complete.
