Looking to migrate from tiscali.
Started by pup, Jan 27, 2008, 21:38:00
Indeed Sebby. Three days at least I would wait. Maybe have a word on Friday morning with support though, so you don't get stuck with it over the weekend :)
pup
yeah itll be fine i know it. i was just like a kid on xmas morning, trying to play with a toy before its completly unwrapped :happy:
Pup
Sitting on the fence......
And Laughing at both sides.
And who can blame you! When i first migrated here, I kept surfing just looking for stuff to download!
RA-1972
pup
#79
 :sigh: wait 3-5 days for profile to recover, wait 14 days to resync router to improve margin (used have dsl modem), then another 14 days to resync again  :sigh:
:rant2: I want it now daddy! :whistle:
:rofl:
Pup
RA-1972
Its took me about 10 days m8 now look at my connection cant fault it dl @ 750 kbs on some dl sites best move i ever made comeing to idnet .
pup
i know it will be fine, just glad to be away from tiscali
:flamethrower: tiscali
Pup
pup
Right im off t bed, night peeps
:yawn:
Pup
pup
#83
 :happy: :happy: :happy:
Yahooooooo My profile has finally updated itself
    IP profile for your line is - 5000 kbps
    DSL connection rate: 448 kbps(UP-STREAM)  5792 kbps(DOWN-STREAM)
    Actual IP throughput achieved during the test was - 2908 kbps
My  sync is a bit lower (proberly because my 3yr old decided to turn the router off yesterday, then 3hrs later the main RCD in the house tripped)  :doh:
I notice that the actual throughput is a bit low, I notice that DeViTTo has a similar issue.
:hug: IDnet
[/URL
Pup
Could be noise, wrong MTU settings or just possibly a line fault. If we can get your stats from you, we can take a look at the most likely cause.
Could also be a BT exchange issue :)
Hmm, something's not quite right there. It could be errors leading to poor throughput, exchange congestion, MTU/RWIN problem, or just some other problem on the line. If you post your stats, it'll help us diagnose further. :)
Can't remember, are you a Speedtouch expert, Sebby. I'm trying to find how to set MTU - and failing dismally. :(
It has to be done via the CLI, Rik.
Telnet into the router and login.
Then, type:
ip ifconfig intf=LocalNetwork mtu=xxxx
And finally:
saveall
Pleasure. :)
Just to mention that, IIRC, it's set at 1500 by default. Really there's no reason to change it on the router; it's better to do it within Windows. :)
Thanks, Sebby. I was just starting on the CLI manual. :)
You'd have been reading that all night, Rik. It's pretty hefty, IIRC. :laugh:
I don't know about you, but I find CLI manuals quite complex. I generally understand what it's going on about, but finding the command you need is often tough.
That was exactly where I was struggling - and the index wasn't helping. I was about to hit Google if you hadn't appeared.
I'm glad I managed to make myself useful, in that case. :)
