Error message
Started by alan, Feb 06, 2008, 09:32:46
alan
Hi again..
When I hit the "Mark as Read" button 9 times out of 10 I get the following error:-
"Session verification failed. Please try logging out and back in again, and then try again."
Any ideas please?
Alan
Hi Alan,
Possibly a cookie problem?  Do you have cookies enabled in your browser, and have you allowed the IDNetters cookie to be permanently stored?
alan
Thanks for quick reply Simon... Yes cookies shown to accept all. I get the warning
on both the Laptop and PC..
Alan
It's odd that nobody else has reported this, which could indicate a browser issue.
Can anyone else replicate this error?
Alan, can you try logging out, then removing the cookie, and logging back in again, so it sets a new one?  Might just do it.
I can't think of anything else, Simon, and as you say, no-one else has reported the problem. What browser are you using, Alan?
alan
Well I was using FF 2.0.0.11...  Still getting the rejection in there. Tried in IE7
pressed "Mark as Read" and they cleared no problem. So it must be something in FF?
Alan
Odd, Alan, I use FF with no problems though, tbh, I never mark stuff as read - I read everything.
What addons are you using?
I use FF as well, never come across that before, and I do mark stuff as " read ", often.
Thanks, In. Do you use many addons?
A couple, smiley extra and spelling checker.
alan
"Mostly Crystal" and "Noia 2(Extreme). Come to think of it I will uninstall both of them. Forgot I had them on there. I'll go back to FF default and see if it makes a difference.
Alan
Thanks, Alan. It's the only variable that I can think of.
alan
Taken Add ons off... Logged off then went into Announcements page in FF
An Error Has Occurred!
Back
Powered by SMF 1.1.4 | SMF © 2006-2007, Simple Machines LLC
Tried IE7 got the same rejection..
Alan
I'm wondering whether it could be a firewall issue, Alan, as it now seems to be affecting your machine rather than a browser. What security are you using, AV, firewall and malware? Which OS version?
alan
NOD 32 3.0.621... Ah.. Come to think of it you might be correct...  Getting the same on PC and Laptop.
Alan
It's the only thing I can think of right now, Alan, but I'll do some digging and see if I can find anything specific on the SMF forums.
alan
Alan
Can you try again now, Alan?
alan
They cleared in FF but not in IE7 that time..
Alan
I've changed a server setting which is supposed to resolve this problem. Give me a minute to take another look and then could your try again please?
Alan, did it make any difference replacing the cookie, like I suggested earlier?  Also, strangely, clearing the cache can often work wonders.
Or, as Rik said.  :)
alan
Simon.. I replaced the cookie but did not clear the cache..
Will try that now.
Alan
alan
Cleared all the cookies in IE7 and now appears to working.. I've actually ran out of stuff to mark as read to try it. ;D.
Alan
