Do I revert back to BT now or after my isp changeover?
Started by David, Feb 07, 2008, 23:57:04
David
As I am now waiting for the big day at present Im a little unsure whether or not I contact BT now and get the ball rolling to get them to take over my line from (sorry) tisca....cant bear to spell it.Mac code got and nearly ready to get a real BB,changing my phone line cannot affect anything,can it? hope i have made this clear,any of your fonts of wisdom will expedite matters. thanks people. :-\
No other number given for release of phone line and from what I have gleaned from surfing around non required.please,if you give me the answer I wont play any James blunt on th piano
I would have thought you needed to get the line back to BT in order to move to IDNet, but if you give the latter a call, they will tell you for sure.
David
Thanks Rik,sort it out in the morning :grn: at least you solved the smiley problems.long live the Rover 400
David
As long as its not two senokot to one part water :hehe:
Quote from: Rik on Feb 08, 2008, 00:38:27
Never necessary in my case. :)
Oh, there's a punchline there, which I will suppress!  ;D
You shouldn't do that, Simon, it's bad for your blood pressure. :)
pup
Quote from: Rik on Feb 08, 2008, 00:23:38
ive just swapped to idnet for bb and left my call with tiscali
Pup
Sitting on the fence......
And Laughing at both sides.
Great news. Your BB will be much better - not sure about the calls.
David
Quote from: Rik on Feb 08, 2008, 23:31:16
I had the same decision to make but if my groundwork is correct,it inst an issue who the line is with,because in reality it is and always will  be BT tiscali and the rest just pay the line rental as we do but provide the call rate,so if anything goes wrong BT will be the ones who correct a fault the provider merely raises an repair ticket.so as far as the line goes although you don't pay BT the line is theirs.In my case I am a very light user with the phone so I opted to return to BT,your call usage may be higher.if your question is does id net line  only work with a BT line I don't know but it would seem unlikely.I chose to leave tiscali altogether ,I had phones with them,but I wanted a complete break its up to you.
I had problems with the line a couple of times and it took a few days longer because BT had to be informed and in my opinion if there is a fault I would rather BT get it sorted with no third party involved
Hope this helps,sorry if its long winded jst tying to cover all points.good luck
David
Quote from: Rik on Feb 08, 2008, 10:04:37
see my advice up above hope it helps
