What do these log entries mean ??
Started by EvilPC, Feb 11, 2008, 21:56:11
EvilPC
As per subject - What's this about ??
WRN    2008-02-09T19:39:10Z    ppp:  ppp0: LCP: timeout sending Config-Requests
NTC 2008-02-09T19:39:10Z ppp:  ppp0: Connection terminated.
WRN 2008-02-09T19:39:41Z ppp:  ppp0: LCP: timeout sending Config-Requests
NTC 2008-02-09T19:39:41Z ppp:  ppp0: Connection terminated.
WRN 2008-02-09T19:40:14Z ppp:  ppp0: LCP: timeout sending Config-Requests
NTC 2008-02-09T19:40:14Z ppp:  ppp0: Connection terminated.
WRN 2008-02-09T19:40:48Z ppp:  ppp0: LCP: timeout sending Config-Requests
NTC 2008-02-09T19:40:48Z ppp:  ppp0: Connection terminated.
WRN 2008-02-09T19:41:26Z ppp:  ppp0: LCP: timeout sending Config-Requests
NTC 2008-02-09T19:41:26Z ppp:  ppp0: Connection terminated.
WRN 2008-02-09T19:42:13Z ppp:  ppp0: LCP: timeout sending Config-Requests
NTC 2008-02-09T19:42:13Z ppp:  ppp0: Connection terminated.
WRN 2008-02-09T19:43:15Z ppp:  ppp0: LCP: timeout sending Config-Requests
NTC 2008-02-09T19:43:15Z ppp:  ppp0: Connection terminated.
WRN 2008-02-09T19:44:49Z ppp:  ppp0: LCP: timeout sending Config-Requests
NTC 2008-02-09T19:44:49Z ppp:  ppp0: Connection terminated.
WRN 2008-02-09T19:47:27Z ppp:  ppp0: LCP: timeout sending Config-Requests
NTC 2008-02-09T19:47:27Z ppp:  ppp0: Connection terminated.
WRN 2008-02-09T19:52:13Z ppp:  ppp0: LCP: timeout sending Config-Requests
NTC 2008-02-09T19:52:13Z ppp:  ppp0: Connection terminated.
WRN 2008-02-09T20:01:16Z ppp:  ppp0: LCP: timeout sending Config-Requests
NTC 2008-02-09T20:01:16Z ppp:  ppp0: Connection terminated.
THANKS
I wonder if it is where the router is trying to 'phone home' and as it is not making a connection, it's timing out?
What version of the router to have and have you implemented the DNS poisioning?
EvilPC
Hi
I have a 2700HGV Dual SSID  Software:  5.29.107.19
DNS Settings are:
pbthdm.bt.motive.com         10.0.0.0         User added
cwmp.cms.smehomehubrms.bt.com       10.0.0.0       User added
pbthdm2.bt.motive.com       10.0.0.0       User added
It probably is it trying to connect to BT's server. What it's saying to you is that it couldn't connect to the other side.
Did you have normal 'net access at the time, EvilPC? It looks a bit like you'd lost sync.
EvilPC
I think so !!  My DSL is up & down at the moment..
BT are looking into it..
what's the best way to find out how many times I've reconnected ??
Have a look here under Training History.
miker
This probably won't make a difference but I read that you should also set;
gateway.cms.smehomehubrms.bt.com                    10.0.0.0
EvilPC
Thanks.
I've added the DNS entry and have found the training details :)
