insert link
Started by Baz, Feb 17, 2008, 17:29:18
how do you insert a link in a post but change the words to whatever you want instead of the long address itself.
understand  :D :D
madasahatter
I've often wondered that too Baz........
Hi Baz
You type [ url=<insert full url>]what you want to call it[ /url], removing the spaces after the opening [ bracket.
eg, [ url=www.bbc.co.uk]BBC[ /url] becomes BBC
ahh!!!   so simple.  So can you use the insert hyperlink icon then change it
cheers Rik
Yup. If you use reply, rather than the QR box, the insert hyperlink does it all for you. We're trying to resolve the code for the QR box.
madasahatter
I'll make a note of that Rik - thanks for the info
