annoying dialoque coming off OE
Started by merlin, Feb 23, 2008, 22:02:50
merlin
windows xp, every time i come off outlook express, up comes a b***** notice which says something like
" windows can compress the mail etc to save space "
i,ve looked every where i can think of to kill this , but back it comes ,anyone know the answer , please please ,
i bet this is one of those things thats so simple "once you know" :doh:
merlin
RIK thanks for the reply. i may not have explained what i needed to do properly.
i wanted to get rid of the pop up message that say "windows can compact etc"
i think your link told me how to use compaction, which is not what i'm trying to do
Quote from: merlin on Feb 24, 2008, 22:08:37
OE compacts after 100 open and close sessions as part of its behaviour, just press yes then it will not do it again till you have used it 100 times, it does this to avoid corruption and you do not lose any messages, If you are fully patched, you will also now see a copy of your dbx files
being copied to the Recycle Bin as BAK files. Should something go wrong when compacting, the messages can easily be restored from this backup. A manual
compact will also reset the counter in the registry back to zero now. For more information look here, http://groups.google.com/group/microsoft.public.outlookexpress.general/msg/116b57f27c55bd59
I have never had issue with OE doing this and just let it do its thing, better it does this than corrupt the  mail database, or let it grow far to large
