Web Mail
Started by wolverene, Oct 11, 2006, 19:01:01
wolverene
Hi all, has anybody tried getting onto the Web Mail today? I`ve just spent the last hour or so trying my various Idnet addresses/passwords and keep gettin the same message as"not logged on check password etc,etc. Very strange
Cheers
Keith
mrapoc
Yea i sometimes get that, try again in a bit
maxping
*Off Topic*
Wolverene this is a long shot but do you play DoD2 on the TLS server?
wolverene
Hi Max, no I don`t play any games at the moment( just as well after following the posts on Pings?) The wife uses the Net a lot logging into her work so would probably keep getting interupted.
Regards
Keith
maxping
I thought it was a long shot , theres a wolverene who plays regularly on the server.
wolverene
If he`s any good I`ll claim his scores!
maxping
rickus
I was abroad from 6-13 October. Admittedly the line was frequently dropping on the PC I was able to use, however I found access to Webmail sproadic.
I could usually get into it but most times it would not let me open my inbox. I found that if I went into search and looked for mails sent to me then it did work.
Have just logged in to it from my home PC and acccessed my inbox fine.
Anyone else had similar experience?
