speed tester
Started by Baz, Feb 28, 2008, 14:52:59
is anyone having bother with the BT speed tester.
I have been getting this error message the past few days ....
Performance Tester was not able to find all the network details required for telephone number:********.
Please check that it is the correct telephone number for your service, and if not try again. If you believe it is the correct number for your service then please raise this as a fault with your service provider.
It's one of BT's lies rather than tell you that it's too busy, Baz. :(
Best time of day seems to be early morning, and our results suggests that you are more likely to get a completed test using IE rather than Firefox.
Ah  good old BT eh :D :D :D :D
yeah it never seems to finish with Firefox even though......."The performance tester has been successfully tested with the following browsers; Firefox, Opera, Netscape, Microsoft Internet Explorer and Safari.......
or is that a lie too BT, eh?
:D :D
thanks Rik
Well, we note what we say, and we note what happens, Baz, so recommend people to use IE. ;)
Just carried out a BT Speedtest using IE6, no problem, I never have a problem using it, it works every time for me. ;)
Everything works for you, In. I'm convinced you have a direct fibre run from Telehouse. :)
Short memory Rik, my graphic card didn't, the other day..  :(
( All OK since I washed it ;D ).
But it worked after you washed it. :)
Quote from: Rik on Feb 28, 2008, 15:26:58
True, I suppose I am a bit lucky really, as has been graphically displayed..  :duck:
Twice this week, In...
Oh yes, and that..  ;)
Noreen
Just done a BT test, with no problems as usual. ;D
QuoteTest1 comprises of Best Effort Test:  -provides background information.
    Actual IP throughput achieved during the test was - 6462 kbps
its working now.
just a glitch eh?  ;)
Noreen
Baz, I can't see your signature image.
edit: now I can, what happened?
His sig was probably doing it's own speed test, Noreen. ;)
