high pings?
Started by GameR, Mar 26, 2008, 20:50:38
GameR
Ive been having probs for last 2 weeks with pings speeds are fine cant complain at that :P,but i wouldn`t mind slow speed if my ping was sweet as am a gamer. I was hoping it would work its self out but it aint its everyday and night ping is normal 25 ,but latey its sometimes tripple that thus causing lag in games which aint to good.The vp for my exchange is green and have done all the usall stuff but its still the same,anyone else got probs with higher than normal pings?
Your line probably has interleaving enabled; do you know if it does? If not, could you let us know what router you have?
Unless your line is good enough to have interleaving switched off, which it probably won't be if interleaving is on in the first place, then there's nothing you can do to lower your pings, unfortunately. :(
GameR
I have 2 routers netgear DG834 with lastest firmware and us robotics 9110 also with lastest firmware,ive tried both and they the same,also have fastpath on and allways have been with idnet since last yr ping allways nice and stable apart from the last 2 weeks.
RA-1972
I have had problems with my pings too it started about 2 weeks ago they where down in the low 20 and now in the 30 and 40 . I do alot of gameing and it doesnt help i know .
RA-1972
heres the link to my thread when i first relised i had a problem .
http://www.idnetters.co.uk/forums/index.php?topic=6657.0
Quote from: GameR on Mar 26, 2008, 21:44:05
Some users have experienced high pings since IDNet did some maintenance a while ago, so it might be worth sending them an email or giving them a call. It could be down to BT maintenance, but it's worth enquiring. :)
RA-1972
I have sent them a email before and sent them some tracert too they said they could not find anything wrong . Gamer where do you live ?
GameR
am in scotland you?
RA-1972
down in devon (england)
RA-1972
just reconnect my ppp session and my pings have dropped again so i will keep an eye on them .
C:\Documents and Settings\
>ping bbc.co.uk
Pinging bbc.co.uk [212.58.224.131] with 32 bytes of data:
Reply from 212.58.224.131: bytes=32 time=29ms TTL=122
Reply from 212.58.224.131: bytes=32 time=28ms TTL=122
Ping statistics for 212.58.224.131:
    Minimum = 28ms, Maximum = 29ms, Average = 28ms
>ping idnet.net
Reply from 212.69.36.10: bytes=32 time=29ms TTL=59
Reply from 212.69.36.10: bytes=32 time=30ms TTL=59
    Minimum = 29ms, Maximum = 30ms, Average = 29ms
Have you let support know?
RA-1972
mmm no i emailed them 2 weeks ago so i might send them a email to let them know what i have done . It might help them .
RA-1972
 :thumb:
The more data they have, the easier it will be to narrow things down.
RA-1972
yeah sent them my old tracert and some ping test from today to see if it would help them .
RA-1972
something happened my pings have really dropped lowest they have ever been , :)
C:\Documents and Settings\>ping idnet.net
Reply from 212.69.36.10: bytes=32 time=16ms TTL=59
Reply from 212.69.36.10: bytes=32 time=17ms TTL=59
    Minimum = 16ms, Maximum = 17ms, Average = 16ms
C:\Documents and Settings\>ping bbs.co.uk
Pinging bbs.co.uk [213.171.192.98] with 32 bytes of data:
Reply from 213.171.192.98: bytes=32 time=24ms TTL=241
Reply from 213.171.192.98: bytes=32 time=23ms TTL=241
Reply from 213.171.192.98: bytes=32 time=25ms TTL=241
Ping statistics for 213.171.192.98:
    Minimum = 23ms, Maximum = 25ms, Average = 24ms
