Bras Profile Changed
Started by crynshame, Oct 26, 2006, 14:03:43
crynshame
Hi All.
As a recent idnetter (almost a month) In my 10 day settling in period I was receiving speeds up to 6.5mb. The figure of 7150k is an indication of the maximum actual data throughput I could expect to receive, after overheads.
Question is; Have been doing BT, ADSL Guide, speed test on a regular basis which have been fluctuating all over the punjab but, still with a line profile of 7150k.
Today this has changed to a line profile of 5000k but downstream seems to be more consistant around 3.5-4.5mb, upstream is constant at 380k.
Can anyone enlighten me why the line profile has changed?
Thanks in advance ::)
Tommy
If its ment for You, it wont pass You.
quandam
#1
Your readings are virtually the same as mine over a similar period. I feel that this is the 'norm'  for most.
Maybe wrong but take a look at other categories on this subject and it would appear that these are the speeds that most can expect.
Thar
Quote from: crynshame on Oct 26, 2006, 14:03:43
For your line profile to change to 5000 you must have had a period of lower sync, between 5696 - 6239Kbps. Are you syncing at 8128 now? If so, your profile should go back to 7150 after 3 days. If not, presumably your line wasn't stable at the higher sync.
crynshame
Thanks Thar
Just completed another bt speedtest and the results are as follows:
Test1 comprises of Best Effort Test:
    Actual IP throughput achieved during the test was - 5383 kbps
Seems the IP profile has gone back to 7150K and has stablised,more than happy with this result. Thanks again :banana2:
Tommy
I think you're only posting this to make me jealous, as the best IP profile I can get is 2500.  :)
