Hooray -- signed up with IDnet at long last
Started by LinLin, Apr 11, 2008, 14:16:48
David
  :phew: more luck than judgment I have only just found the preview  :thumb:
thanks Rik
It's the button marked Preview, David. ;D :out:
David
You need to have an L smiley Rik  ;D
Thanks for sorting the quote out I was trying  :karma:
NP.
You just need a [ /quote] (no space) at the end of the piece you're quoting, then add your reply after the closing bracket (preferably with a couple of carriage returns...
David
Just realized when trying to type my wireless keyboard isn't functioning properly..time for new batteries.thats not an excuse but a possible reason for a few things  :whistle:
LinLin
Wow -- my speed test is fantastic. I was promised up to 4 kbps... the test comes out 5.251 kbps.  :thumb:
Upload is 366 kbps.
Wow.
David
Great news, LinLin. If you can get a BT test at some time, that will tell us what your profile is set to. (http://test.speedtester.bt.com:50301/)
LinLin
How is this possible? Again, I was told to expect up to 4 kbps. I just tried a different server site (limerick) on speedtest.net, and it came out even higher than the last one -- 6.682 kbps.
The BT test you linked to showed:
    Actual IP throughput achieved during the test was - 6525 kbps
not sure what it all means, but there it is.
It means that you have an excellent connection LinLin. :thumb:
That's the one that matters, LinLin.
You have the maximum possible sync speed and a profile to match. Allowing for overheads, your connection is going about as fast as is possible (I'm jealous!). Speedtest.net can produce some pretty interesting figures, often faster than is physically possible. I'm not a great fan of the site.
If you check in the Netgear ('show stats' button), what is your downstream attenuation and noise margin?
LinLin
ADSL Link             Downstream     Upstream
Connection Speed    8128 kbps    448 kbps
Line Attenuation         26 db         6.5 db
Noise Margin                   9 db           24 db
Again, WOW!
You even have some noise 'headroom' to play with. That connection should be flat out all the time. (I'll be round to borrow it shortly ;))
Quote from: LinLin on Apr 11, 2008, 17:18:03
Again, WOW!
You live in the exchange too LinLin??
Glad to see that LinLin is getting all the help she can from Idnetters, some of it even helpful. :whistle: >:D
LinLin
QuoteYou live in the exchange too LinLin??
Is there info there about location? I'm near Dunfermline...
http://www.samknows.com/broadband/ should help you find it.
You look to be about 2.5-3km from the exchange.
Welcome to IDNet, LinLin. It's good to see that you're up and running, and with full sync. 8)
LesD
Regards,
Les.
Noreen
 :welc: LinLin  :karma: Make sure that you come and join us in IDNatters. ;D
Noreen
Quote from: LinLin on Apr 11, 2008, 15:03:24
:blush:  Oops -- yep, that's the one. Just was on the phone to tech support (they were great) and they reminded me the username is admin and the password is password!
I believe that it's recommended that you change the router password to something more secure, LinLin.
Good spot, Noreen, I was so busy making sure everything else was OK, I didn't pick up on that.
Malc
Philip
Captain K
Hi LinLin.  :welc:
You'll love it here - once we've warped your sense of humour sufficiently!  :pullface:
Bruce.
I don't trust Camels.  Or any other creature that can go a week without a drink.
