Refurbish desktop Hard or within reach ?
Started by David, Apr 22, 2008, 12:19:21
David
David
Well that was very fast.the ram I ordered yesterday afternoon has just been delivered very good service from crucial...have to double check they are the correct modules for the machine but I am optimistic as they worked it out from the scan and the motherboard installed so will install them in a little while.this will all being well double the ram... :fingers:
Great service as usual from Crucial, just remember that they only fit one way round David, there is an offset slot so you cannot get them the wrong way round.
Also just pop the end clips down before fitting them, then with even firm pressure just push downwards on them,  the end clips should just close themselves .. sorted. :thumb:
David
 :thnks: ....Im glad these things didnt get lost in the post...cant remember the last time I had amnesia  ;D
I've never liked tinned rice pudding. ;D
David
Got the sides off and Im looking at two memory slots which have modules in no room for any others,am I supposed to replace the existing ones ?
Quote from: badpianoplayer on Jun 14, 2008, 12:47:51
Yes David.. :thumb:
Just press down on the end clips to release them.
David
Can I be excused for not knowing this please.. :blush:
You are excused David ;D, some Motherboards have 4 memory slots, but as yours has only 2, not a lot of choice. ;)
David
I just knew it was too good.....these do not fit...having taken mine out I see that the installed ones are DDR 533 CL4
yet the ones I have recieved are DDR 333 CL2 and they dont fit.in the centre of the of the DDR there is a slot which on the pcs is a arch like cutut but on th enew ones its not matching up...time to Email them I guess and whilst these are out will take the correctg number
which number would you qoute ?
I am no expert David, but I would have thought that they should fit, they may not be absolutely identical.
Rik etc. will advise further. ;)
Have you tried fitting them both ways round, David?  The slots on the modules are offset, so the modules only fit one way into the motherboard slots.  It's unusual for Crucial to get it wrong.   :-\
It seems that yours may be DDR2 type David, in which case they will not fit, DDR2 are the newer and cheaper type.
See here for more info;
http://en.wikipedia.org/wiki/DDR2_SDRAM
How about a quick pic of the two side by side, David?
According to Wikopedia the speed that David quoted means that the new ones from Crucial are DDR, his existing ones are DDR2.
So it seems that Crucial got it wrong. :(
David
They sent DDR 333
Mine are  DDR2
The centered is too far offset for them to bed in.....
That's poor.  :(  Time to get onto Crucial then, David.
Exactly David, they are the wrong ones, they will not fit. :(
Yours are DDR2, faster and cheaper.
A bit late now but this a free tool that I use to find out exactly what my computer hardware is.
:thumb:
http://majorgeeks.com/download4181.html
It is no longer supported but still works fine.
David
Quote from: Simon on Jun 14, 2008, 13:19:13
yes Simon this makes the centre lug even more off so no chance here..
