Printer,help me choose
Started by David, Apr 29, 2008, 10:04:19
 :lol:
A karma for your efforts then. :)
David
Quote from: badpianoplayer on Apr 29, 2008, 13:32:47
Yes but I didn't say I had arrived....just getting there. :rofl:
There done it  :blush:
David
David
Quote from: Rik on Apr 29, 2008, 11:40:03
I'm very pleased with my Canon, David, and it's way better at text than the Epson ever was.
Just found one £99 refurbished full warrenty money back if not satisfied ? Canon M970
Is it a discontinued model, David?
David
No Rick checked double checked same one as the link all spec is same picture and specs same,just refurbished
Odd. I Googled it and drew a blank...
David
Found it. No networking though. :(
David
You little sherlock you.networking ,is that important Rik
Personal preference, David. I like to have one printer at least that works straight off the router, so that it's available to any machine that's on the LAN. The rest I hang off my main machine, and they are available when that's on, which is most of the time.
David
Its only for me though Rik
In that case, it's fine without. You can make it a shared printer, and then install it to other machines if you find the need.
David
I just love a bargain.....5% for you on that site isnt it Rik  ;D ;D
Which site, David? If it's Misco, you can get an extra discount by going through Quidco.
David
what is quidco ?
sorry if Im late in replying using IE7 seems better than FF
It's a weird cash-back scheme, David. Perfectly legitimate, but I don't understand why merchants sign up to it.
http://www.quidco.com/
David
Just reading this good link looks promising  :karma: :thnks:
I've never used it, but everyone seems to rate it - the discount on Sky is particularly good. What I don't understand, though, is why any merchant gives cashback through a third-party site.
David
Low discount for larger share of the market worth the small percentage given away.bit like the theatre bums on seats.?
Or an offset for saved advertising costs? I don't get it, but you will get the cashback, though I do believe it takes a little while to come through.
David
Better in my pocket than thiers,every little helps  ;)
What are you going to buy with it? ;)
David
Debit card Rik,credit card is emergency only  (like a new pc) lol
I was just thinking you'd have spent the full sum, so you could apply the discount to some other purchase...  >:D (Don't forget to order a USB cable if you don't have spares. Chances are it doesn't ship with one.)
