printable cds
Started by sobranie, May 07, 2008, 17:02:11
May I ask members who are using printable CD's which manufacturer they are using and possibly advise any probs they have had with cheapo suppliers.
Thankyou in anticipation.
Verbatim and Maxell, they seem best suited to my Optiarc drives.
Panasonic and Verbatim here. :thumb: :)
Verbatim are showing strongly. :) (They also manufactured the first pack of floppy disks I ever bought...)
verbatim it is then. I was rather hoping it would be as I've always used them for normal cds and dvds.
Thanks all.
Malc
I buy from bowlers computer fair in Machester, (insert any comp fair) unbranded, maybe an odd bad one, but other than that no probs.
Niall
I've got a DVD burner (Lightscribe) and to this day I've never bought any discs to try it :D
Flickr Deviant art
Leo Tolstoy
You should give it a try, it really is good! :)
Quote from: Rik on May 08, 2008, 09:09:26
If slow. :(
If I want a CD printed that badly, I would by the original if its music based, cant be doing with Lightscribe
