Loss of LCP last night
Started by Ray, May 11, 2008, 09:14:48
Did anyone else lose LCP connnection last night just before midnight mine went down at 23:59 and took until 02:13 to successfully reconnect I kept getting Chap authentication failures. BT at it again I wonder?  >:(  ???
It's likely to have been BT, Ray, but let me go check my log...
Nothing in my logs, Ray - so it's not likely to have been an IDNet issue as I think we are both on DSL4.
Nope, not loss of PPP here, so was perhaps BT. I'm on GW5 - are you on DSL4?
 :mad: :mad: :mad: :mad:  tell me about it...
Ive been struggling with a bad line fault all week, now Ive been told that BT dont operate on domestic adsl lines outside of normal hours, so it will be monday now. Last week it was tues cos of the bank hol.  :bawl: :bawl: :bawl:
feels like Im on dial up
I'm sorry to hear that, Baz. I hope the problem is resolved quickly. :(
If you will insist on dealing with a second-rate ISP, Baz. ;D :out:
dont tempt me Rik, it has crossed my mind. Have to give them a chance I suppose.
BTW  you hoping to get back in the other forums ;) ;) ;) ;D ;D ;D
Quote from: Sebby on May 11, 2008, 10:16:05
thanks Sebby. That saying is right, you dont realise what you got till its gone :D
Quote from: Baz on May 11, 2008, 10:19:22
I live in hope, Baz. :)
Quote from: Rik on May 11, 2008, 10:16:39
come on then........sell it to me  :)
IDNet are the beeknees. Enough said? :)
Quote from: Rik on May 11, 2008, 10:22:07
joking Rik, honest, we need you over there. Its not often we get expertise like yours. :)
thats a pretty weak sell guys  ;D ;D
I heard the same lines before I joined where I am now and that was 7 years ago
I didn't have any PPP drop last night either - not at those times anyway :)
My line looks like it has been a yo-yo all night, caused by massive noise margin swings as much as 8db (from 6 to -2). TIme for a resync I think as the current is 2688 at a margin of 17db!
Messy, Lance. BT must have been unplugging the DSLAM all night. :(
Nope - I think it is my line.   >:(
I just resynced to 5088 with margin of 6, and then a few secs later the noise margin was down to -1.
edit: From the logs, it looks like 40 loss of signal errors in 24 hours. Not good, and I'm surprised my target noise margin is still 6!
It sounds like there's some serious noise fluctuation there, Lance.
Or you're using a Netgear... :out:
It's on my 2wire! I've had this before, but it always seems to sort itself out after a few days and any line tests IDNet run come back clean.  >:(
 :bawl: :bawl: :bawl: :bawl:  im on a netgear too .dont give me more grief please ;D
YEAH!!!!!!!!!!!!  netgear rule  :D :D :D :D :D ;) ;)
Quote from: Lance on May 11, 2008, 10:31:16
You're not alone. Test socket time...
Quote from: Baz on May 11, 2008, 10:33:47
We don't need to if you use a Netgear, Baz. ;)
when you use the test socket and you have a faceplate fitted do you need to put a filter in too
