Recovery software
Started by Glenn, May 13, 2008, 17:46:47
Guys, a quick question, my brother just brought a Dual SSID 2700 with the VCI set to 35, he asked my the following;
Do you reckon my router can use the recovery software
Serial Number:
300611033661
Hardware Version:
2701-100588-005
Software Version:
5.29.117.3
Any ideas?
None, I'm afraid, Glenn. Can he not simply factory reset it, then do a manual setup?
Ted
You can use the SingTel 5.29.117.3 Firmware but NOT the SBC 4.25.19 Firmware.
Tell him to look HERE for more info.
Ted
Cheers Ted, I'll point him there.
He may join the forum too.
He can't use the recovery firmware. What's the problem? If it's that the VCI is set to 35, that can be changed...
No need to change the firmware, just run the System Setup from the Home page, it allows you to select the correct parameters
Follow this Simple Guide for a troublefree setup.
