TI v10 and Vista SP1
Started by Noreen, May 13, 2008, 19:18:50
Noreen
This thread is interesting especially to me as I have both, I've disabled the item for now. http://www.wilderssecurity.com/showthread.php?t=208493
I suppose Acronis must operate at low level to do what it does, but I do wish they would get their act together a bit more, I always get a sense of holding things together with bits of sticky tape. :(
Noreen
Yes and your backup program is the last thing that you want held together with sticky tape.
I seem to be lucky and haven't had any problems with TI on vista (pre or post sp1).  :fingers:
Quote from: Rik on May 13, 2008, 19:28:02
I use Memeo AutoBackup (my Western Digital My Book came with a license key). It seems to work okay, but I get a similar impression (the sticky tape thing).
Noreen
I haven't either but I thought that I'd give the recommendation a try as I've seen it suggested elsewhere that most people don't need it. I can always turn it on again if necessary.
The worry with acronis, is that their are no program updates occurring anymore. I heard they lost a programmer, even T11 has had no update since 12/07 :)
That is quite worrying, but surely one programmer wouldn't make that much difference?
#9
:eek4:
Edit: Smiley markup sorted
Quote from: Lance on May 14, 2008, 07:57:40
Seen it happen with security suites Lance, all you need is the brains of the outfit to go and the rest are left flapping in the wind  ;)
