Routerstats SNR wave
Started by gingerjedi, May 14, 2008, 13:10:47
doc_holiday
Quote from: gingerjedi on May 16, 2008, 16:07:51
I've just ordered one of these, I don't know if it will make much difference but it's worth a try over the standard flat ribbon cable I'm using now, saying that... I do wonder why I bother shielding the last 7 feet when BT doesn't give a toss about the other 7,000.  :-\
I've got one of these. I can't tell you if it was worth it or not, because I never tested it with a cheapo cable. At least it looks more impressive than the flimpsy white ones!  ::)
That said, my line noise has crept up in the last few months, so I'm replacing the wall filter and am making a few changes to the house wiring.  From my point of view, using good leads, filters and keeping your lines in good nick can only help.
Absolutely, plus, unless there's a clear fault external to our properties, it's the only thing we can do.
