Rubbish Speed
Started by wrtpeeps, Jun 02, 2008, 14:48:06
wrtpeeps
    DSL connection rate: 448 kbps(UP-STREAM)  5056 kbps(DOWN-STREAM)
    Actual IP throughput achieved during the test was - 75 kbps
Says it all really.  >:(
Don't eat yellow snow.
Do you have a lot of errors on your line? Do you know if BT are working at your exchange?
wrtpeeps
There is no work going on.
I have a WAG354G and can't find where to look for the errors.
I've never used that router, but I'm sure someone else will be along shortly. It is definitely a localised issue to you, though, either your line or exchange.
dont know if this is any good routers but you can select your router there and it shows how to fins stats
and here
If you can, it would be worth trying another router. Otherwise you should let IDNet know about this. Sync looks fine, as does the profile, so other than the router, I can only think it's BT.
Quote from: wrtpeeps on Jun 02, 2008, 15:02:16
Do you have any other machines connected to the router? Are results similar across all machines if that's the case?
wrtpeeps
Quote from: Rik on Jun 02, 2008, 18:36:00
I just tested and it seems only my machine is affected :(
wrtpeeps
by the way, should i be on pppoa or pppoe?
madasahatter
It should be PPPoA  :)
wrtpeeps
Quote from: madasahatter on Jun 02, 2008, 19:24:13
Thought so.
Well I did the tweak test at dslzone and it said everything was fine.
If the problem is only on one of your machines, then I suggest that you run antivirus/spyware scans etc
wrtpeeps
I changed the plug my homeplug device was in and the problem seems to be solved. Weird as **** eh.  :laugh: :laugh:
Philip
Quote from: wrtpeeps on Jun 02, 2008, 19:52:09
happy days, nice one  :thumb:
Glad you have sorted it.
Is your machine connected wirelessly? Perhaps changing the channel may help; try 1, 6, and 11 before the others. You could try connecting by cable (if it's not already) also to see if it's the wireless.
He is using a Home Plug Device Seb..  ;)
It's now sorted..
Possibly an extension or surge suppressor? Glad it wasn't an IDNet issue anyway. :)
