slow speed
Started by ST Driver, Jun 03, 2008, 13:29:11
ST Driver
Hi
having speed problems again to day
tried changing filter, leads, different computers
but no difference
speed test results and router stats attached
any ideas
Grandad Racer
Unfortunately, I'm on my mobile so can't see the attachments, but someone else will be along to help, I'm sure. :)
You can't see them Sebby, because there aren't any..  ;)
ST Driver
#3
Ok I'm having a bad day forgot to post attachments :blush: :blush:
test done at 09.00
    IP profile for your line is - 7000 kbps
    DSL connection rate: 448 kbps(UP-STREAM)  8096 kbps(DOWN-STREAM)
    Actual IP throughput achieved during the test was - 4609 kbps
test done at 13.00
    Actual IP throughput achieved during the test was - 1695 kbps
Stream Type
Interleaved Channel Data Rate
Up Stream  448 (Kbps.)  Down Stream 8096 (Kbps.)
Noise Margin
Upstream 26 dB  Downstream 8.5 dB
Output Power
Upstream 11.5 dBm  Downstream 20 dBm
Attenuation
Upstream 21.5 dB  Downstream 35 dB
Edit: Attachments pasted into post
Grandad Racer
:rofl:
The WAP interface doesn't show them anyway. :P
For your benefit Seb;
test done at 09.00
and;
Stream Type
Noise Margin
Output Power
Attenuation
Something is wrong there, Steve, your throughput nowhere near matches your profile. It could be exchange congestion, BT work or an IDNet issue. Best bet would be to have a word with support, let them have the BT speedtests, and see if they can spot a problem.
ST Driver
thanks Rik
will ring them later
Grandad Racer
Do you have the number? 0800 0267237 or 01462 476555 if you prefer a geographical number, eg you're using a mobile. They are there until 18:30.
ST Driver
Just got to go sit in out patients with the wife, so could be some time ;)
Grandad Racer
ST Driver
#12
Hi
Just a quick update. spoke to support last night
and eveything seems to be back to normal now,
as ca be seen from this mornings bt speedtest.
    Actual IP throughput achieved during the test was - 6469 kbps
Edit: Speedtest result pasted
Grandad Racer
A result, thanks for the update.. looks good. :thumb:
Quote from: ST Driver on Jun 04, 2008, 09:14:53
Did they say what the problem might be?
Good result. I'm interested to hear whether there was a problem or whether it's jus returned to normal. :)
ST Driver
I haven't heard from support so I don't know if of what the problem was.
Just pleased things are back to normal so quickly and with a minimum of fuss.
:solved:
Grandad Racer
ST Driver
Had email from support saying congestion at exchange
Grandad Racer
Thanks, Steve. The curse of every ISP, as it's completely out of their control but affects their customers. :(
