Alternative sync software to synctoy?
Started by mrapoc, Jun 05, 2008, 16:13:25
mrapoc
Hiii guys
Synctoy (microsoft) was my sync software of choice previously. Used to keep it on my usb and sync college work to usb and then usb to home pc afterwards. It has now decided its not going to launch/work at both locations ?!
Anyway Ive tried reinstalling and the newest beta (error whilst running) and im now after a new one.
Dont mind on cost, nothing too simple and something i can use easily and trust to do it right (a preview option would be good as would a backup or something)
thanks111!
I use the pro version of Goodsync available here I've used it for a couple of years now and found that it works well.
mrapoc
mrapoc
tried them both and rik's was a lot more effective/easier to use
karmic both of you  :thumb:
doc_holiday
Quote from: Rik on Jun 05, 2008, 16:24:16
Take a look at SyncBack, Sam:
http://www.2brightsparks.com/syncback/sbse.html
I use Syncback. My only gripe is that I have not been able to make the scheduler work reliably for some reason... (though I haven't really push it too hard either)
I always do manual backups, so that I know they've worked. Could the scheduler be part of the paid for version?
Does Syncback die after the 30 day trial
No, it's free for life, Baz unless you downloaded a trial of SyncBack SE.
thats all I can find Rik, the 30 day trial from here
am I on the wrong page
