PC Crashed again with alarming message
Started by David, Jun 17, 2008, 11:17:25
You've been very quiet the past few days, Jill. Everything OK?
David
J!ll
Quote from: LesD on Jun 20, 2008, 20:49:59
Good work David,  :thumb:
Here is another way to get an overview of what you computer build is.
Use:
Start -> Help and Support -> Use Tools to view your computer information ...... -> My Computer Information -> View general system information about this computer
Using this route in XP should show you a picture like the one I have attached below.
8)   :thumb:
J!ll
#128
Quote from: Rik on Jun 21, 2008, 19:01:38
Overworked  :( dealing with the union  ::)
J!ll
I think I should be a union rep  >:D my research is correct, according to my local rep, who dislikes my team leader  :whistle: is standing by  :thumb:
David
David
J!ll
David
J!ll
LesD
Quote from: vitriol on Jun 20, 2008, 23:12:22
Hi David,
Here is a little uility that will give you information about your CPU, Motherboard, Memory etc...
A favourite of mine too vitriol!  :)
Well worth getting hold of David.
Regards,
Les.
vitriol
GPU-Z is a similar utility but for grapics cards.  Handy for keeping an eye on gpu temperature.
I find an app that Noreen posted a few months ago is very helpful SIW http://www.gtopala.com/
vitriol
nice app, loads of information in there
thanks
David
RAM upgraded at last the 2 1 GB sticks arrived today and took all of two minutes to install.(have had enough practice)just checked and lo and behold my computer etc reads 2 GB Ram so I think this saga has come to an end.........................unless ? :fingers:
Nice one, David, glad you finally got there.  ;) :thumb:
David
Thanks Rik I kept very silent.the error was on the initial scan they had not flagged that it was an upgrade but I would still use them again and to be honest it didn't break the bank @£12.99 each so although some confusion it all worked out in the end  ;)
David
Quote from: Sheltieuk on Jun 27, 2008, 12:45:11
Thanks Ray I have been busy shopping around looking at various sites with the view to build one,have to increase the budget though as £500 is not enough when I take into account all the parts etc and If I go ahead I would get the best I can afford.not a cheap hobby but still keen on building one... :whistle:
Quote from: badpianoplayer on Jun 27, 2008, 12:50:08
It's a very satisfying experience, David, I've done it about 4 times now and not encountered any un-surmountable problems although the air tended to turn blue at times and the language a bit ripe  :), they all ended up working OK with no damaged components.
Be careful though once you've successfully done one it can become rather addictive.  :) ;)
David
 :think: :comp: batter than Valium and it will keep me amused  ;D
