General software updates
Its the client i use as well for ftp-ing stuff for the forum!
Well it shows how much I use an FTP client, I'd forgotten that I had FireFTP installed, it's been that long ago since I used it, I was just about to download and install it. :doh:  :P :stars:
Ah, but have you updated it, Ray? :D
Quote from: Rik on Feb 24, 2009, 14:27:06
looks like it, Rik.  :D
Flash player 10.0.22.87 released
No wonder they're being slow on the Acrobat patch. Thanks, Gary.  :thumb:
Windows Live Messenger has an update today too
I can sleep through that one. Thanks, Glenn.  :thumb:
Luckily, in all sorts of ways, I don't. :)
Noreen
New edition of SIW (computer auditor) available. You can update from inside the program ;D.
Noreen
"SUPERAntiSpyware 4.25.1014 released February 24, 2009"
Technology Changes
* Smart Definitions to detect zero-day threats
* Vundo/SmitFraud Detection Enhancements
* Enhanced Diagnostic System to detect rootkits/cloaked malware
* Improved rootkit removal technology to handle rootkits that disable security applications
* Numerous technology additions to the scanning engine
* Updated Direct Registry Access (DRA) Techology
* Updated DDA (Direct Disk Access) - faster and more reliable
http://www.superantispyware.com/prod...PERANTISPYWARE
http://www.superantispyware.com/download.html
I've had an update for MS Silverlight delivered via Windows Update on Vista today, as well as another to correct a DRM fault in WMP when its getting updated licenses.
I suppose I should check, but then I hardly use either. :)
I can see Silverlight having great potential once more is developed for it.
Or Moonlight, if the open sourcers win. :)
Perfect disc 10 build 100, bug fixes.
I had an update to google earth earlier, from v4 to v5 but as i hadn't used it for a while this could be old news!
Quote from: Lance on Feb 25, 2009, 23:38:07
New version now comes with Google update and no way not to install have it Lance  :( but it is better than version 4 so its swings and roundabouts with Google as always
Quote from: Lance on Feb 25, 2009, 18:54:04
Silverlight sites are pretty good, and movie clips using it instead of flash player are great
CCleaner 2.17 released bug fixes and a new feature, wipe free disc space space
