General software updates
0 Members and 7 Guests are viewing this topic.
Quote from: Lance on Apr 30, 2009, 13:59:12
Windows Vista doesn't use a web browser for updates though, and surely updates could be downloaded on another machine and pushed/pulled accross the network as exe files?  :)
Build a WSUS http://technet.microsoft.com/en-us/wsus/default.aspx
Quote from: sparky on Apr 30, 2009, 09:07:46
There was a lot of problems with IE8 Beta and online banking.
It didn't work with Nat West.  Anyone used it with HSBC or Nat West ??
I guess the only way is to try it, but can you backtrack to IE7 if it doesn't work?
I suspect they were resolved. If not, doesn't IE8 have that compatibility view for sites that don't render properly? It's funny that Microsoft have had to put that feature in so that IE8 works with sites that have formerly had to be hacked to work in IE in the first place! :)
Firefox update to 3.0.10
dont know if its already been posted
Twice is better than none at all, Baz.  :thumb:
Twice in the space of a week if you're Mozilla. :P
Firefox, the iTunes of the browser world. :)
IE8 works fine with Natwest for banking if you set it up to be in compatibility mode it downloads a constant list of what needs to be run that way so you don't have to, I have left it on manual as sites that say they are broken seem to run ok anyway so far.
CCleaner 2.19.900 released thats twice in one week, reason being "due to a new version of Firefox (3.5beta4) that was released the same day and an IE8 cookie bug that crept back in"
Quote from: Gary on May 01, 2009, 15:35:50
CCleaner isn't under the new ownership of Mozilla, is it? :whistle: ;D
:rofl: :karmic:
Naah, it's being written by the iTunes team. :nana:
Shockwave player 11.5.0.596 released
edit* CCleaner 2.19.900 appears to have a bug, if you store passwords in FF cleaning saved form history will also wipe out your passwords, the way to avoid it is untick that option or exclude the file. The file name for exclusion is signon3.txt just hunt out it in your profiles.  :)
I see another update coming on. >:D
I told you it was the iTunes crew. :)
Noreen
Quote from: Noreen on May 07, 2009, 17:46:03
Another CCleaner update.
Cheers Noreen, its on the CCleaner page now so you can get he slim build  :thumb:
Fresh from the presses.....  Open Office 3.1 is released today.
