General software updates
If you don't visit porn sites, you've got nothing to worry about. :D
I'm not sure, I just got that from the BBC article. :)x
 ;D
I didn't understand either.  8)
Apple has released an updated version of Java.
http://support.apple.com/kb/HT3581
Shockwave player 11.5.0.600 released
Firefox 3.5 RC1 released
Noreen
New version of IrfanView available. Quote copied from another forum.
QuoteIrfanView Version 4.25 Released
http://www.irfanview.com/
(does not show on his site yet)
http://majorgeeks.com/IrfanView_d4253.html
Note that the installer version also attempts to install the Google Toolbar.
If you do not want the Google Toolbar, de-select it.
The ZIP version does not contain the toolbar.
Version 4.25      (Release date: 2009-06-16)- New capture option: Region capture (Thanks to grebulon)  (as option in Capture dialog or hotkey: CTRL + PrintKey)- OCR Feature/PlugIn added (Options menu, Hotkey: F9, full image or selection)  PlugIn download: http://rerecognition-download.ch/irfan/kadmos44/KADMOS.htm- New command line switches for /capture  4 = use region capture, 5 = start in capture mode using dialog settings- New and re-arranged Properties dialogs- New Color Management options in Properties->Viewing (new LCMS PlugIn needed)- Burning PlugIn: can burn using Nero or Windows interface (WinXP or later)- Support for JLS format (JPEG-LS, PlugIn by KATO Kanryu)- Support for WBZ/WBC/WB1 formats (Webshots formats, PlugIn by V. Paramoshin)- New display option: Use Resample for zooming (Menu: View->Display options)- New fullscreen option: Use Resample for zooming (Properties->Fullscreen)- Option to save changes on exit in now also used for image/file change- New option in Batch-Scan dialog: Remember last scan counter- Previous "Search files" dialog results showed again on next search- Batch rename dialog: Last 15 rename patterns are saved- New Thumbnails sort options: Sort by image DPI- New placeholder: $p (image DPI)- New buttons/options in File-Replace dialog for multiple files- Resample bug with very special images fixed (TIF bug reported by Secunia, thanks!)- The option "View->Lock zoom" works now with all display options- Show PNG and TGA/DDS alpha color options merged (Properties->Viewing)- New command line option: /reloadonloop  Reload input source used in /slideshow when list is finished- Command line, /convert: exit codes added: 0 = OK, 1 = load error, 2 = save error- Support for TIFs with 12 bits per channel- New option in Postscript PlugIn: Enable Antialiasing for better quality- New button in EXIF dialog: Show in GeoHack-Wiki (for GPS coordinates)- New help menu: Check homepage for updates- Browsing hotkey: CTRL + SHIFT + number (0-9), decrease file index by number
Thanks, Noreen, just in time for me to upgrade the Sammy. :)
Noreen
4.25 is now on the IrfanView site.
Noreen
You don't have to remove the previous version, just install new version over the top.
Thanks. I'll try and find time tomorrow.
Noreen
Will you be on the forum tomorrow, Rik?
I will, in between packing, polishing the car and doing the tyres, fluids etc, but I intend to be off by 6pm, as we leave for Scotland at 1am, and I'd like to grab a few hours sleep.
What amazes me is the numbers of mains chargers I'm packing, phone, iPod, PDA, Sammy, toothbrush, cameras (2), camcorder etc. Life used to be simpler. :)
I think you need an iphone 3 GS  :evil: then anything extra would be the toothbrush and a decent camera!
Will you tell Sue or shall I, Steve. ;D
RogerP
Hi
software version 3.0 out for iPhone  and Safari 4.0.1 out also
Rogerp
Thanks, iPhone 3.0 being discussed here if you're interested. :)
New update to safari 4 for mac already and bluetooth firmware update.
Malwarebytes 1.38 released
    *  (FIXED) Minor issue with updating.
    * (FIXED) Certain types of freezing during full and quick scans.
    * (FIXED) Problem with Estonian language and installer.
    * (FIXED) Certain folders showing up as files in results list.
    * (FIXED) Scan time improperly displayed if Abort Scan clicked after Pause Scan.
    * (FIXED) Error during loading log files after database update.
    * (FIXED) Issues with freezing in protection mode. Certain conflicts with anti-virus software.
    * (ADDED) Some proxy support, please see /proxy command line parameter.
    * (ADDED) New command line parameters: /logtofolder, /logtofile (see help file).
trophymick
I did the Irfanview update this morning, I've just resized a photo for email, and tried to 'save as' and it wants me to go to another (3rd party) site, and I need a code. Uninstalled the updated version and reinstalled the previous one. :thumb: Maybe it's a change of policy from Irfanview? :dunno:
Am I being thick? :whistle:
Mick
