General software updates
Quote from: Rik on Jul 24, 2009, 10:32:30
For the time being.  :eyebrow:
Well till about 12:30pm probably  ;)
Quote from: Rik on Jul 24, 2009, 11:44:10
That long?  ;)
Well its Friday, so I am being optimistic  ;D
CCleaner 2.222.968 released
Redesign of Cleaner results panel.
- Added support for Opera 10 Beta.
- Added support for Safari 4.0.
- Added search to Uninstall tool.
- Added search to Cookies screen.
- Improved User assist cleaning in Windows 7.
- Fixed bug in OpenOffice cleaning.
- Fixed IE8 SuggestedSites.dat cleaning support.
- Fixed UI bugs.
Super antispyware Version: 4.27.1000
Changelog:
    * Many internal scanning engine updates
    * Direct Disk and Registry Enhancements
    * Improved hidden service and hook detection
    * Improved application blocking protection (startup when infected)
Noreen
Can someone remind me, when updating SuperAntiSpyware, do I have to delete the old version and install the new one?
Noreen
So how do you update it, Rik? Sorry, I'm feeling a bit dim today.
I usually just hit 'check for updates' then let it do its thing. It all happens 'in situ'.
Noreen
I meant update the version, Rik.
Sorry, doing that seems to update the program for me as well. Either that, or I've been completely misreading the update process.
Noreen
Is yours the free version and what version no. do you have, Rik?
Free and 4.27.1000, which doesn't look that recent...
Noreen
It's the latest, I think. Clicking Update only updates the defs for me.
Same here. I don't know why I thought it didn't look right, really. It's been a long day.  :stars:
Noreen
So to get back to the nitty-gritty, I have to re-install the program to get latest version.
I didn't, if that is the latest. It appeared to update the program when I did a check for updates.
on the main window click 'Preferences' then the 'Updates' tab then 'Check for updates now...' button.
the Check for Updates on the main window just does the definitions
DarkStar
It's as Rik says Noreen, it will update automatically when you check for updates but new version updates as opposed to signature updates are rolled out over several days otherwise the servers would crash if everybody tried to update at once.
I think but am not 100% certain that if you do download the new version you can install it over the top without uninstalling. Used to be able to do it that way but don't have SAS on board at the moment because of conflicts with other software - Outpost in particular.
Ian
Quote from: DarkStar on Jul 29, 2009, 17:36:43
You can just install over the top as DarkStar says, I only use it as a resident scanner, no active protection, but the download is available online if you need it.
Noreen
Thanks, Baz, that did it. ;D
