General software updates
Quote from: Gary on Sep 23, 2009, 21:37:00
Nod 32 4.0.467 released
•Fixed: External driver injection in ESET SysRescue on Microsoft Windows 7 RC fails when this option is selected in the advanced mode of ESET SysRescue wizard
• Fixed: Error sending a file via "Send to" in the right-click menu. The problem only occurs in combination of Microsoft Windows XP and Microsoft Outlook 2003 when the Microsoft Outlook process is not running.
• Fixed: Mozilla Thunderbird with IMAP account freezes when a virus-laden message is received
• Improved: Compatibility with server operating systems
• Improved: HTTP scanning compatibility
• Other minor fixes and improvements
Gary is this the anti virus or the combined one from NOD.I have the av but am only on v3.0.xxxx  and thought I was up yo date.that seems a big jump if its the one I need. Also I have never been able to update from the program itself, is there a way or do you need to go to the site. From the program I can only do the database updates unless I'm missing it some where.
Quote from: Baz on Sep 24, 2009, 08:22:14
Its for both ESS and the stand alone AV which I use like yourself, you need to download the new version, Nod32 will not update versions from 3-4. v4 has been out a while and while some consider it to have had issues, I personally have thought it to be good, this latest build is very smooth, it has self protection, lacking in v3 and improved trojan ad rootkit detection, have a look at AV comparatives to see Esets current position (they could do better) but they are beating Kaspersky. Its for me a solid upgrade, try it, if you don't like it go back to V3  :) Also the latest V3 is 3.0.694.0.
Ah yes of course, I remember the fuss about it now.Thats why I was holding off.Can you easily go back to earlier version if needed, although i think I have the set up file somewhere
Thanks Gary
Quote from: Baz on Sep 24, 2009, 10:17:52
Thanks Gary
Just uninstall and go back Baz  :thumb:
For those of us with Logitech Squeezebox hardware changes are in the offing http://forums.slimdevices.com/announcement.php?f=12
Niall
I like the way they call it an ecosystem :D
Flickr Deviant art
Leo Tolstoy
talos
CCleaner v2.24
By email today
PerfectDisk 10 build 124 released
# New Features
   1. PerfectDisk 10 Server Virtual Edition supports VMware vSphere™ 4.0.
   2. PerfectDisk 10 for Exchange supports Microsoft Exchange Server 2007 Service Pack 2.
# Bug Fixes
   1. Analyze statistics does not list pagefile on system drive on Windows 7.
   2. PerfectDisk terminates when a shortcut to a network shared folder (.lnk file) is selected on "Selected Files" dialog.
   3. Offline defrag settings for a drive are not in effect at boot time defrag when "Defragment on EVERY reboot" is ON.
   4. AutoUpdGui.exe hangs running under local system account.
juiceuk
Microsoft has released an Update which allows the 64-bit versions of Windows Vista SP2 and Windows 7 to take advantage of the enhanced C1E state on AMD multicore processors to lower power consumption by an additional 10%. Note that this hotfix update can only be provided upon request using this form.
probably should have gone in general software updates? sorry bout that.
Adobe reader 9.2 released, critical security fixes.
Superantispyware 4.29.1004 released, rootkit detection enhancements and language updates
There is a new Letterbox beta 5 out for mail Mac OS X,seems to work well http://harnly.net/software/letterbox/.
I like the 2 line subject columns. :thumb:
Sounds like 10.6.2 is on the way
Thanks, Steve. Tbh, I've had no issues with b4.
CCleaner v2.25.1025 released.
- Improved Windows 7 jump list cleaning.
- Improved Windows 7 thumbnail cache cleaning.
- Added support for Windows Server 2008 R2.
- Improved 64-bit support and performance.
- Fixed issue with Windows 7 task scheduler.
- Fixed issue with Startup tool, displaying incorrect folder contents.
- Added support for AVG Antivirus 9.0.
- Added support for ExcludeKey in INI files.
- Improved support for wildcards and RECURSE/REMOVESELF.
- Fixed minor GUI bugs in non-English versions.
- Fixed minor GUI usability issues.
- Improved input validation.
- Lots of minor bugs fixed.
talos
Thanks, done,   Doesn'T seem much different.
Quote from: Gary on Oct 27, 2009, 09:46:10
You won't have to worry about this soon. :)
Quote from: talos on Oct 27, 2009, 11:19:58
They never do, its always incremental changes but you do often wonder whats been done.
Quote from: Sebby on Oct 27, 2009, 14:12:00
True. its going to be odd not needing so many utilities for maintenance. Its a bit scary tbh  :blush:
Don't be scared. Embrace the simple life that is Macintosh. ;D
Quote from: Sebby on Oct 27, 2009, 17:29:26
I hope to, as my Mac was a custom order only the applecare will get to me friday, the iMac will be with me between the 3rd and 6th so next week  :bawl: I want it now  ;)
I know, the wait is agonising, but it'll be worth it. :)
