General software updates
Thanks, Gary. Yet another round of updates - or I could just move to Safari as Apple keep nagging me to do. :)
Quote from: Rik on Mar 26, 2008, 08:13:27
Would not do that Rik, http://secunia.com/advisories/29483/ pretty bad considering its only just been released really and is buggy as hell on Windows from what I have read
You can turn off the nagging in Tools if you use the apple software updater by setting it to ignore updates you don't require :)
Where do I do that, Gary, I keep unchecking it and it keeps coming back...
Quote from: Rik on Mar 26, 2008, 08:30:09
Go to Apple software updater open it leave the updates you dont want ticked then go to Tools, ignore selected updates, then press quit
Dumb question, Gary. Where do I find it, I have nothing in the start menu or CP.
Quote from: Rik on Mar 26, 2008, 08:41:22
Ahh when you installed your Quicktime stuff did you untick install Apple Software Update or remove it after installation? it should be in your start menu just called apple software update. it just checks once a week for new updates, or how ever long you have it set to, saves having to keep checking through Quicktime etc
I must have chosen not to use it - it's not there, but the iTunes helper is running, which may be triggering it...
Quote from: Rik on Mar 26, 2008, 08:53:33
could be, its a useful little app so if you get a chance to on the next update its worth it, nice to turn the nagging off ;)
I'll keep my eyes open, thanks.  :thumb:
Quote from: Killhippie on Mar 26, 2008, 08:46:52
There is an option when you install iTunes to not install the automatic updater. :)
#311
You know when you've been Apple'd...
:back:
I'm afraid you can't legally install Safari, Rik, as El Reg have pointed out.
Maybe I should read every post on the forum before posting anything myself!!!  :whistle:
You mean to say that you don't, Lance? :no:
:rofl:
Mytheroo
PIE patch to version 3.141592654
There are 10 kinds of people, those who understand binary and those who don't.
Quote from: Lance on Mar 27, 2008, 22:29:59
How much time do you have? ;)
Shockwave player to version 11.0.0.0
Thanks, Gary. If only the software houses would get together and post us a DVD each month with all the patches on it...  :sigh:
Quote from: Rik on Mar 28, 2008, 09:59:36
Its such a great Idea Rik, it would make life so much simple  :stars:
Think of the load it would remove from the 'net...
Quote from: Rik on Mar 28, 2008, 10:13:09
It would be a great Idea, setting up my new pc there were so many updates from just the day before typically my luck that a disc with "this months" latest common software updates would have been great :) and as you say the load off the net would be amazing
