General software updates
Noreen
Update version 3.0.2.2448 of MailstoreHome now available here
Any significant changes, Ray?
This is the info from the web site, Rik.
MailStore Home 3.0.2
2008-12-09
    * New Export to Mozilla Thunderbird and Mozilla SeaMonkey
    * New Filter archiving by e-mail date (only e-mail before a specific date)
    * Improved processing of non standard-compliant e-mail
    * Fixed Misleading error message "Index corrupt, please rebuild." under certain circumstances
That will please Simon.  :thumb:
Quote from: Rik on Dec 23, 2008, 16:24:51
Yep, he always did hate the misleading "Index corrupt, please rebuild" message. :P :out:
 :nana: :tongue: :tongue: :nana: :nana: ;D
I meant SeaMonkey, of course. :)
:hehe:
Sometimes, I just can't help myself... :)
I know, but the tablets are beginning to work, Seb. :)
Noreen
Just read on my American forum of several people having this problem with the new version of IrfanView, I haven't installed it yet myself. Most forum members seem to be reverting to the previous version until it's sorted out.
QuoteIf anybody here is having troubles with the Left-Right Arrows, you're not alone. For some reason the Left & Right Arrows on the Tool-bar won't work properly when Browsing through a Folder with Numerically sequenced Image Files, (ex. Clipboard01.jpg, Clipboard02.jpg, Clipboard03.jpg, ... etc.)
If I Click on the Right Arrow to go to the next File up from Clipboard01 to Clipboard02, it won't budge, but if I Click on the Left Arrow I can go in the Down direction and start from the "Top" of the order.
All appropriate Settings were Set in the Options > Properties/Settings > Misc.1.
I spent all morning trying to figure his out. Finally, I Re-Installed the Previous Version and it works like a Charm.
Edit: The Left & Right Arrows still work OK on the Keyboard.
Noreen
Don't know about anyone else but I've now installed the NOD32 update after reading good reports on Wilders, people are saying that it's faster.
Quote from: Noreen on Dec 24, 2008, 17:41:00
Running well here Noreen and it does feel faster browsing as well  :) I had to change from Kaspersky as it just causes endless bluescreens on 64bit systems which for me is a shame as it was fine on 32 bit not what i needed, but Eset is running well here :thumb:
Noreen
Noreen
New version of Foxit Reader. http://www.foxitsoftware.com/pdf/reader_2/down_reader.htm
From my American forum...........
QuoteNote that the .exe (& presumably the .msi) will attempt to install toolbars & things like that. If you do not want them, deselect them on install (or use the .zip version instead).
Also note that installation gives the impression that Typewriter will not work if the toolbar is not installed. That is not the case. Typewriter will work, it is just that if the document is saved it will contain watermarks (with the free version of the reader).
Thanks, Noreen.  :thumb:
Good Christmas?
do you know if you get the option during install to not select the toolbars Noreen of will it auto install them
Noreen
I'll let you know when I install it, Baz.
BTW the bug in IrfanView is now acknowledged  http://www.irfanview.net/main_start_engl.htm
Quote from: Baz on Dec 27, 2008, 11:49:53
Yes you do, but just watch it very carefully. There's quite a few tick boxes throughout the setup process that you'll want to untick!
Noreen
I decided to use the zip version. Seems OK. ;D
Additional toolbars are the bain of my life, they cause no end of grief, especially when people install multiple toolbars.
