Deleting System restore files
Started by Wingco1, Jul 18, 2008, 13:54:43
Wingco1
Someone kindly posted how to reclaim bags of HDD space by deleting old SR files. Try as I may I can't find the post  :(
Can anyone help?.
Try this? If your using XP it should by default pinch about 12%, you can reduce the size down to say 5% by changing the settings in control panel>system>system restore
LesD
#3
Goto System Properties (right click My Computer)
At the System Restore tab click the box by "Turn off System Restore on all drives" to put a tick in it and click OK.
Reboot and then visit this tab again and remove the tick from the box.
All old restore points will be gone so I should set a new one pronto.
An MS Article on the subject is here.
Regards,
Les.
net91
Open Disk Clean up by going to Start, All Programs, Accessories then System Tools.
Click the More Options tab, and then click Clean up under the System Restore and Shadow Copies heading. You will be asked to comfirm you want to delete all but the most recent restore point.
This method is for Windows Vista but should be the same for Windows XP.
Dan
Wingco1
 :blush: Thanks everyone. I think I've just had a senior moment  :whistle: I think I've confused the system restore with HDD management  :blush: :out:
Are middle aged moments less serious then senior moments?
LesD
Quote from: Glenn on Jul 18, 2008, 16:32:00
Middle aged or Senior moments and I can relate very readily to the latter  :)  butI would still recommend an occasional deletion of old Restore Points  ;)
I do it when I think things running well  :fingers: so that once done and a new one has been created I have a sound point to restore to!
Regards,
Les.
Cannot remember ;D
Noreen
Anyone who is really considering deleting System Restore Points in Vista should be aware that it will also delete all Shadow Copies of documents and any Complete PC Backup images at the same time, so think carefully before doing so.
MoHux
Also, for anyone thinking of dual-booting.
Changing O/S removes all System Restore points.
"Microsoft apologises"  ::)
Mo
LesD
In view of what Noreen says below:
Quote from: Noreen on Jul 18, 2008, 17:51:01
I had better qualify what I said in the following:
Quote from: LesD on Jul 18, 2008, 16:38:13
but would still recommend an occasional deletion of old Restore Points  ;)
as being applicable to my experience with XP Pro. I have not ventured in to the realms of Vista myself.
Regards,
Les.
madasahatter
You might be better off with the WRVS, Mad. ;)
madasahatter
Quote from: Rik on Jul 19, 2008, 11:11:28
:lol:
I've got me name down with the Sally Army  ;D
The Sally Gardens would have been more fun. ;D
