Router issue?
Started by Moley, Aug 16, 2008, 12:58:04
Moley
Hi peeps, not been around for a while sorry  :blush:
We've been experiencing the odd service drop - mostly during the evenings between 9 and 10pm. I suspect our router is dying, but is there anyway to check that this is the case before buying a new one?  We're on gw5.
Cheers
Hi Chris
Connection drops at that time of night are more likely to be a noise problem than the router. Can you post your stats, daytime and around that time of night?
Moley
Aye I've gone and bought new router - Linksys WAG160N - its got fab reviews.  I can no longer connect to the router wirelessly and it keeps switching itself off - so I think as its 4 years old its just had it.  Will let you know how it goes when I've connected it up..... Wish me luck - hope the wizard is easy as I'm bit of a  noob....
You shouldn't really need the wizard, Chris, but  :fingers: anyway. :)
Moley
Didn't need the wizard as you said.  So far its awesome - speed much better, wireless connection effortless - still having the odd drop in the evenings though - few seconds but enough to interrupt world of warcraft....
Sounds like you still have noise around you, Chris. Try and get the stats close to when the line drops and also early morning.
Moley
Ok noob question - how do I get these stats you speak of?   :conf:
