Everything owned by Microsoft is down for me! MSN, Xbox Live, - the lot!
Started by netgem21, Aug 19, 2008, 18:22:45
netgem21
OK, I still can't find anything about MTU but it's randomly started working now. Guess support found the issue. Thanks Rik! :)
Not necessarily, they had no problems with the site when I spoke to them, so it may have been just that one part of the site that was affected.
What router do you have?
RichR
For tracert on OS X either use Network Utility in /Applications/Utilities. Click on the Traceroute tab, enter the IP address you're interested in and click start.
If you're feeling brave you can use Terminal, also in /Applications/Utilities, and type traceroute www.msn.com
Quote from: RichR on Mar 31, 2009, 15:49:28
Good to know! :thumb:
D-Dan
I have to admit that I haven't read all this thread, but I started at the beginning and came straight to the end to see if there had been a change of focus. So if this has been mentioned, I apologise.
Conficker blocks access to all sites with "microsoft" in the url, amongst others including "antivir", "conficker" and several others. A quick test would be to google "conficker" and look for a result where "conficker" is part of the URL, and try to access it. If you can't get there either, come back because there's a way around it to get to the removal tools.
Edit: BTW - the virus is set to activate tomorrow - so if you have suspicions you may be infected - act now.
Have I lost my way?
Quote from: D-Dan on Mar 31, 2009, 19:51:30
Exactly, act now - get rid of Windows! :whistle:
uxbod
would somebody please try getting to www.zimbra.com or www.zimbra.com/forums for me please ? I cannot get to any of these sites at all.  Worked fine first thing this morning.  Yet I get alerts of thread updates; and one of the other mods says he can connect just fine :(
GW6 atm. Routing shouldn't be affected by gateway, though.
A tracert for me shows:
tracert www.zimbra.com
Tracing route to www1.zimbra.mail.vip.ac4.yahoo.net [76.13.17.53]
over a maximum of 30 hops:
  1     1 ms     1 ms    <1 ms  home [192.168.1.254]
  2    22 ms    21 ms    23 ms  telehouse-gw2-lo1.idnet.net [212.69.63.51]
  3    22 ms    21 ms    21 ms  telehouse-gw3-g0-1-400.idnet.net [212.69.63.243]
  4    22 ms    23 ms    25 ms  redbus-gw2-g0-1-331.idnet.net [212.69.63.5]
  5   101 ms   102 ms   100 ms  83.245.126.11
  6   101 ms    98 ms    98 ms  xe-2-0-0.msr2.ac2.yahoo.com [216.115.108.127]
  7   100 ms   102 ms    98 ms  te-9-1.bas-b1.ac4.yahoo.com [76.13.0.207]
  8   107 ms   100 ms   100 ms  www1.zimbra.mail.vip.ac4.yahoo.net [76.13.17.53]
Trace complete.
uxbod
snap ... this is so weird :(
Yet my traceroute is different on GW6 :-
cisco877#traceroute www.zimbra.com
Translating "www.zimbra.com"...domain server (212.69.36.3) [OK]
Type escape sequence to abort.
Tracing the route to www1.zimbra.mail.vip.ac4.yahoo.net (76.13.17.53)
  1 telehouse-gw2-lo2.idnet.net (212.69.63.55) 40 msec 48 msec 48 msec
  2 telehouse-gw3-g0-1-400.idnet.net (212.69.63.243) 40 msec 48 msec 52 msec
  3 redbus-gw2-g0-1-331.idnet.net (212.69.63.5) 40 msec 40 msec 44 msec
  4 83.245.126.11 120 msec 112 msec 104 msec
  5 xe-2-0-0.msr1.ac2.yahoo.com (216.115.108.123) 108 msec
    xe-7-0-0.msr1.ac2.yahoo.com (216.115.108.125) 112 msec
    xe-2-0-0.msr1.ac2.yahoo.com (216.115.108.123) 124 msec
  6 te-8-1.bas-b1.ac4.yahoo.com (76.13.0.205) 116 msec 116 msec
    te-9-1.bas-b2.ac4.yahoo.com (76.13.0.211) 112 msec
  7  *  *  *
It looks like your IP address may be being blocked - can you ask anyone at the site?
uxbod
Cheers Rik ... I have pinged a couple of the employees to see if they can check it out for me ... Well gets me out of some moderating I guess ;)
Unfortunately, I'm not in your IP range to test, and IDNet are all in the same range as me. :( If it's of any use, I can ping you fine (I'll PM a tracert if you want one).
uxbod
It a internal network issue @ Yahoo :) Thanks for your help Rik (again) :)
