Extremely Slow
Started by Nutter, Aug 27, 2008, 20:48:46
Good to hear, Steve. :)
Nutter
So are most people sorted out speed wise now?  Mine has been peforming fine since the re-balancing, though I haven't had chance to move the router to the master socket yet to get a better profile and get the final extra bit of performance.  It's still good though as it is.
Philip
Quote from: Nutter on Sep 16, 2008, 13:50:56
It's all been very quiet on that front for a while now, glad to hear your connection is OK though.  :thumb:
Mine would run faster if it didn't have to resend 500,000 corrected blocks each day
David
Just read and carried out speedtest Im blistering along and have been since support sorted it out  :thumb: :thumb:
This is good to hear!
David
Better to experience Sebby  ;D ;D
Blisters? I'm not sure I agree. ;)
David
Im trying to keep up so blisters ? pass the savlon  ;D
You might prefer a paraffin dressing. :)
keep away from naked flames though
An unlikely response from BT
    Your DSL connection rate:  is aflame(DOWN-STREAM),  damp squib(UP-STREAM)
    IP profile for your line is – Red hot
    Actual IP throughput achieved during the test was –blisteringly fast
Digging through some old doc's from Tiscali days
    Your DSL connection rate:  dribbling(DOWN-STREAM),  struggling(UP-STREAM)
    IP profile for your line is – like a candle in the wind
    Actual IP throughput achieved during the test was –Unable to complete but the Tortoise is odds on
 ;D
Roll on 300 baud, eh, Steve. :)
David
jaydub
As one of the posters reporting poor speeds, I have to say how impressed I've been by IDNet service since.
Since I last posted, support got in touch with me and following a bit of tweaking my speeds have been much better and certainly outperforming the speeds I got at NewNet.
I have since had interleaving removed from my line in the early hours of Wednesday morning and apart from a few CRCs when the phone is in use, the line is error (and disconnect) free.
I have to say that the BT system is doing its best to not raise my profile, which should by now have jumped from 6500 to 7150.  I've raised a call with Support which should see BT kicking their system into action in the morning.
I'm certainly much, much happier than when I've arrived. :D :D :D
Philip
great news, jaydub  :thumb:
Thanks for reporting back, Jaydub.  :thumb:
Glad to hear of the improvement I suppose it could take 10 days to get from a profile of 6500 to 7150 as 7000 is the next one up.
David
 :thumb: :thumb: Good to see Jaydub  ;D
vitriol
#321
    Your DSL connection rate: 8128 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
    Actual IP throughput achieved during the test was - 3092 kbps
I wouldnt say everyone is out of the water yet.  Still it is peak time ish....
Some router stats
ADSL Link                     Downstream     Upstream
Connection Speed          8128 kbps        448 kbps
Line Attenuation            21.0 db            10.5 db
Noise Margin                 9.0 db              23.0 db
Netgear DG834GT with latest firmware.
Does that look normal?
If you not done so collect a series of BT tests and contact support.This what I did and since their intervention my evening peak time speeds have been much better.There is nothing else abnormal with the stats apart from the throughput.
jaydub
Well I'm all right, Jack :D
Just ran a speed test and the profile seems to have jumped to 7150 on the basis of IDNet saying they would log a call with BT in the morning.
    Actual IP throughput achieved during the test was - 6470 kbps
Great news. :thumb:
Can I have some of that speed please? ;D
