Can XP Pro be activated with an early XP Home Key Code?
Started by LesD, Aug 28, 2008, 20:28:02
LesD
Here's hoping!
I have and early but genuine and legal XP Home CD with its Key Code.
Using this to install XP you then have to add SP2, SP3 etc. I have these Service Packs on CD's but I also have a genuine legal XP Pro CD with SP2 "slip-streamed" into the installation process. This version has already been activated on the PC I am using now.
The question for the forum experts at large is this, would it be possible to install from my XP Pro +SP2 installation CD and activate the installation with the genuine XP Home key code?
I ask because one is Pro and the other is Home?
I have used the XP Pro +SP2 install CD with a genuine XP Pro +SP1 key code successfully but this latest desire just might be a bridge too far!
What does the forum think.
Regards,
Les.
The simple answer is no I believe the key code is specific to the OS version whether it be XP Home XP pro OEM etc
net91
I tried to do something very similar in a virtual machine once. It didn't work.  :)
Dan
LesD
Thanks for the replies. In my heart I knew as much and took the long way. In the event once Home was installed adding SP2 was a relatively quick process. I will put SP3 in probably later on today.
Regards,
Les.
I always assumed that SP3 contained all the updates so you could have managed without SP2 unless obviously you are downloading SP3 and wish to keep the download to a minimum.
LesD
I have SP3 on CD and I pondered the same thing but as the Home version didn't have SP1 I was not sure about going straight to SP3 so I decided to put SP2 on first.
So far so good, with nothing downloaded so far. Mind you I rarely use a fifth of my monthly bandwidth so I doubt that I should worry on that score!
Regards,
Les.
Except that you've only got two and a bit days to use this month's, Les. ;)
Quote from: Rik on Aug 29, 2008, 10:13:20
Good point Rik, I am up against the buffers this month on my allowance, looks like I may for the very first time get charged extra, which is a bit sick really, 'cos many months I hardly use my connection at all.
I vote that we have a 12 monthly allowance..  ;D
It would be an interesting marketing move, In. If people paid annually, they could be given a block allowance for the period. OTOH, technically, that makes it hard to predict network usage...
I am just avoiding any downloads until the month is out ..  :fingers:
Service packs are cumulative, Les, so they include all previous updates. It's the same with firmware; just can just load the newest.
drummer
Microsoft tend to contradict themselves on occasion:
To install SP3, your computer must meet the hardware and operating system requirements listed below. In addition, your computer must at least be running Windows XP with Service Pack 1 installed.
We recommended that you have Service Pack 2 installed before installing SP3
http://technet.microsoft.com/en-gb/library/cc164204.aspx
But the download pages make no such stipulation.  Go figure.
Quote from: drummer on Aug 29, 2008, 12:16:52
We recommended that you have Service Pack 2 installed before installing SP3[/i]
I wonder if they mean when installing the service pack on Windows? Perhaps SP2 has some files that the SP3 setup needs or something like that. Certainly when you slipstream, you'd only need to do SP3.
What you get up to in the comfort of your own home is your business. :eek4: ;D
LesD
Thanks Drummer as the grey matter ages I begin to doubt my recollection ability but the one you quote is what I had read a month or three ago when I put SP3 on this machine!  :thumb:
This vague recollection tempered what I did last evening with a bit of caution! I'm glad it did now.
Regards,
Les.
JB
JB
