Billion 8800 firmware update available
Started by Postal, Sep 30, 2021, 15:59:26
robinc
Clive
I have that router so how do I get the update?  :D
Postal
Quote from: Clive on Oct 02, 2021, 11:56:59
Before you start the backup process, log in to your router, got to Configuration > System > Backup/Update and save your current settings.
Then click on the relevant link in my original post, download the file to your hard disk, log in to the router, go to Configuration > System > Firmware Upgrade, browse to your saved file, then click on Upgrade.
I have always seen it recommended as best practice that you upgrade to the Factory Default Settings rather than Current Settings then re-create your own settings or re-load your saved configuration but I have always just upgraded to Current Settings and not had a problem so far (says he touching wood).
The whole process takes about 10 minutes.
robinc
Go to https://support.billion.uk.com/index.php?/Knowledgebase/List/Index/106
Select the relevant version for your router model
Download the manual - bottom of the list of updates. The upgrade process is on PDF page 111 (actual page 107)
This will also help http://www.billion.uk.com/esupport/index.php?/Knowledgebase/Article/View/377/106/how-to-perform-firmware-upgrade-on-bipac-78xx-and-88xx--series
Download the relevant firmware file for your version as linked above - and do make sure you get the right one.
Access your router via the web interface - default 192.168.1.254:8888 login as provided by idnet.
CHECK YOUR CURRENT FIRMWARE VERSION!!! Status>Summary
The newer firmware is not compatible with older settings config files so beware the temptation to reload saved settings the first time you do this. I was on 2.52.d1 and those settings could not be re-used. Now on 2.52.d16 which would be re-usable.
In the end I took screenshots of the Configuration Pages to make sure I had the DNS, DHCP and NTP settings. After applying the upgrade rebooted with default and just entered the login and aforementioned - rebooted it and all was well.
Current uptime since update - mid May!
Clive
You know what?  My favourite saying is "if it ain't broke, don't fix it."  :whistle:  Thanks both for the clarification.
Postal
Quote from: Clive on Oct 03, 2021, 17:18:46
If I'd known that was your default position I wouldn't have wasted my time writing things up for you.  Thanks for the heads up for when the next question comes along.
Clive
Many apologies if I caused offence but it seems a bit too complicated for for me to handle.  On the other hand, when my son comes home at half term with the grandchildren he will probably cope with it.  So your effort is very much appreciated.
nowster
The update's description suggests that it's a cosmetic fix only, so not an urgent update.
Postal
Quote from: Clive on Oct 04, 2021, 13:53:52
No offence taken.  However, it is not a complicated process so I'm sure you wouldn't have any problems in handling it.  Writing it up (particularly to the level of robinc's posting) takes far more time and effort than actually doing it.
Postal
Quote from: nowster on Oct 05, 2021, 10:49:17
Without knowing details of the existing firmware on someone's router, no way of knowing whether there have been any critical updates or security fixes since it was last updated.  Just because the latest update seems to be cosmetic only doesn't mean that a router is not in need of an urgent update.
